Creates configured RSVP-TE profile with the specified profile name.
| profile_name | Identifies the RSVP-TE profile. The character string must begin with an alphabetic character and may contain up to 31 additional alphanumeric characters. |
| standard | The standard option differentiates this command version from the command that creates a fast-reroute profile. If you do not specify an option, a standard RSVP-TE profile is created. |
N/A.
This command creates a configured RSVP-TE profile with the specified profile name. The default profile cannot be deleted. If a profile is associated with a configured LSP, the profile cannot be deleted.
A profile name must begin with an alphabetical character and may contain alphanumeric characters and underscores ( _ ), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For name creation guidelines and a list of reserved names, see Object Names in the Switch Engine v33.1.1 User Guide .
The following command creates an RSVP-TE profile:
create mpls rsvp-te profile prof598
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
